Old 21-Aug-2012, 1:18 PM   #2
signals unlimited
DTV reception solutions
If your roof is standard shingles, there is no foil backed insulation and no large trees or buildings in the direction of your stations.
A little more antenna will do the job.
There are two channels to your East, WPOX 4, and WKOB 2. These are LP's with no major network affilation. If you want these channels you need a large all channel antenna. The Winegard 7015 should do the trick.
If you have no interest in these LP's a better choice would be the Winegard HD7697P. This is a fairly large High VHF/UHF antenna designed to recieve channels 7-51 and should enable your 'cut'.
