Old 20-Aug-2012, 10:35 PM   #4
Tv Reception.
For reception of the main group of Digital Tv stations/channels to the south.
Install a Winegard HD7698P antenna aimed at about 180 degree magnetic compass direction.
For 1 Tv connection use no splitter.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com , http://www.channelmasterstore.com.
The Tv Must channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
