Old 20-Aug-2012, 9:17 PM   #6
Tv Reception.
A Simple reception situation.
For reception of the Digital Tv stations/channel to the north east at about 30 degree magnetic compass direction.
Above the roof install a Winegard HD9095P antenna aimed at about 30 degree magnetic compass direction.
For 2 Tv's connected use a common simple 2 way splitter.
Here is how aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
As always , tres and tree leaves do a real fine job of , reflecting , reducing , blocking , Tv reception and so do buildings and other obstructions.
It is best to locate the antenna at a location where there is the least amount to no amount of obstructions in the direction of reception.
