Tv Reception.
Locate the antennas at a location where there is the least amount to no amount of obstructions in the way of reception.
_______________
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
