Anyone? Maybe someone from this area of WA that receive signal from the Seattle towers can chime in with how they did it?
This Antenna I have is rated more than high enough to receive signal from 40 miles away. My Pre-Amp is apparently the best at something on the market. Whatever that means.
All the other stations for 60+ miles in any direction work just fine. Like they are streaming over super high speed internet. Even when it rains hard and the wind blows the antenna all over the place.
But I get nothing from 4, 5 7, 9, and 11. I need a solution that reflects this. I need a solution that is specifically designed to pick up highly scattered signal.
And I don't have disposable income to burn on making it happen. As I mentioned in the first post I have an old parabolic from direct TV I can modify if need be.
And to be clear the goal is to overcome the diffraction if that is even possible.
