Old 19-Aug-2012, 11:30 PM   #14
signals unlimited
You should have no problem receiving virtual 5 with your setup.
before looking further, be sure that you are aimed to 121 degrees magnetic.
Now for a 'double rescan'. Remove the antenna signal from your set and run a scan. Reconnect the signal and scan again.
If that fails, the amplifier and possibly a few extra feet of elevation may help.
