Old 19-Aug-2012, 8:26 PM   #3
Tv Reception.
The following is a Teleview recommendation for reception of broadcast Tv .
For reception of the Macon and Columbus broadcast Tv stations/channels , Install a Antennas Direct , Clear Stream 2 Complete UHF/VHF antenna above the roof aimed at about 80 degree magnetic compass direction.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Also install a Antennas Direct CPA-19 preamp.
Remove the reflector screen from the CS2 Complete and the antenna will also receive Columbus stations in opposite direction.
Here are some places to buy antennas and etc. , http://www.soldsignal.com , http://www.amazon.com , http://www.antennasdirect.com.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Mount the antenna at a location that has the least amount to no amount of obstructions in the direction of reception , north east , east , south east.
