Old 19-Aug-2012, 5:15 PM   #3
Tv Reception.
Your location has Tv transmissions in All 3 Tv channel bands.
UHF band channels 14 thru 51.
Examples:
WOCK-CD , REAL VHF low band channel 4 , virtual number (x) ,http://americaone.com.
WBBM-DT , REAL VHF high band channel 12 , virtual number (2.1) CBS.
WFLD-DT , REAL UHF band channel 31 , virtual number (32.1) FOX.
_____________
Install a antenna that is Designed to receive All of the Digital Tv channels.
Install a Winegard HD7082P antenna above the roof aimed at about 126 degree magnetic compass direction.
Use a common simple 3 way splitter to connect the 3 Tv's.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna,
