Tv Reception.
A Teleview Recommendation for Tv Reception.
Yes 16 AWG thick antenna mast is good to use. It is stronger.
Yes use the 4560 eave mount you have selected.
The bottom mounting bracket is extended out , and this will produce more distance between the top bracket and the bottom longer bracket.
This will make the mast more stable.
