Old 19-Aug-2012, 1:25 PM   #2
signals unlimited
Simple DTV reception solutions
If there is a clear view from the chimney to your main group of stations at 125 degrees magnetic.
Install an Antennas Direct CS2 complete, aimed to 125 degrees.
Run a new RG6 coax to the input of the first splitter.
If you have sets with DTV (ATSC) tuners you need to go into the menu and change them from CABLE to AIR/ANTENNA channels, then run a channel scan. If you are using older sets you will need converter boxes.
DONE!
The antenna and mount can be purchased from www.solidsignals.com.
