All good information, and absolutely right! Now, the issue is whether or not you are willing and able to install a roof-mounted antenna: If you are, then you will need a near-fringe directional antenna. possibly along with a rotator, to get everything that is available to you. Good choices would be the Winegard HD-7696P or the AntennasDirect HBU-44. Should you want to turn the antenna to see the San Jose, Sacremento, San Francisco and Sonoma stations, you should consider the Channel master 9521a rotator or the AntennaCarft TDP-2. You will NOT see most of the San Francisco stations without a rotator and such an antenna.
