Old 19-Aug-2012, 1:33 AM   #2
Tv Reception.
Out on the East patio , a ANT751 antenna aimed at about 90 degree magnetic compass direction.
http://www.solidsignal.com , has a ANT751 antenna with a J mount type antenna mount , low dollars.
The best way to get the coax from the antenna on the patio to the Tv in the apartment is the coax goes through a hole through the wall.
Here is another way to do it , Flat Coax # 144823.
http://www.hollandelectronics.com , and also at , http://www.solidsignal.com.
The Tv Must Channel Scan for the Digital Broadcast Tv Stations/Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Can also try reception with the ANT751 antenna inside of the apartment with the ANT751 aimed through the glass patio doors.
