Thread: Cabling or Amp?
Old 18-Aug-2012, 9:59 PM   #3
Tv Reception.
For reception of the Tv stations/channels you have listed and More.
________
A common way of coax wiring in the past in Older buildings.
Is chaining splitters one after the other. One splitter connected to an other splitter connected to an other splitter , and at the end of chain of splitters the signals are Very Weak because each time a split takes place the signals are reduced.
A Better Way to do coax wiring is have 1 splitter or distribution amplifier and from that 1 splitter or distribution amplifier , a coax will go out to each location.
Install a Antennas Direct CPA-19 preamplifier.
For one Tv connected use No splitter/s.
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
For 4 Tv's connected use a HFS-4D , 4 way splitter.
Order the HFS splitters from , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
_________
For your reception location Remove The Reflector Screen from the CS2 and now the CS2 will receive Tv stations/channels to the , north west and south east with either side of the CS2 aimed at about 305 degree magnetic compass direction.
Also order and install the VHF channels 7 thru 13 antenna kit that installs on the CS2 UHF antenna.
For better reception of , WILL-TV , VHF channel 9 PBS.
Here are some places to buy , http://www.solidsignal.com , http://www.amazon.com , http://www.antennasdirect.com.
