Unless your cable shows signs of deteration, it should be ok. IMO quad sheild is a waste of time and money.
If you only intend to run the one set, just find splitter and locate the line to the TV. Use an "F" barrel splice to tie the line from the antenna and the set togather. With the antenna aimed to the group of stations to the NW. rescan.
If you want to use four sets, at the location of the splitter, install a Channel Master 3414 distribution amplifier. This will give you four outlets. If you need five Channel Master has amps for more, but dont over do it. Open outlets must be terminated.
Examine all connectors and replace any that are not properly installed or otherwise suspect.
