Omni directional antennas leave you open to multipath problems more than any other type. Most directional antennas tend to be least sensitive to the sides but quite often can receive fairly well from the rear... relative to the sides.
I should have mentioned, face the antenna to the north. The stronger signals from the south will be received with power to spare.
You may not see real CH-10 & 22 but NBC-Shopping and a network feed that's available from WLVI to the north makes me think it's not to bad a compromise.
