Old 18-Aug-2012, 12:09 AM   #2
Yaguy
RE: Coax loops for rotator and Chimney Mounts
What I was trying to get at is for those of us with chimney mounts who have a short, unguyed mast section and then the mast section above the rotator, both not too far away from my chimney, has anyone found that the coax has found a way to rub the bolts on the rotator and, short of winding it around the rotator like some do with heavier coax used in HAM radios, I don't really know how to keep the loop away. I was even thinking of maybe using that flexible, plastic wiring protector hose or tubing that can be pulled over wire, like you see in automobiles.
Yaguy is offline   Reply With Quote
