Old 17-Aug-2012, 10:46 PM   #6
Originally Posted by pensivenk View Post
Thanks for your response. It is very helpful. If I can try outdoor antenna, do you have any recommendation other than C4? I think I may need the strongest one. Thanks again.
I would consider the Winegard HD7968P and Antennacraft HBU-55. Regardless of which one you choose, an Antennas Direct CPA-19 preamp would also be needed to overcome cable and splitter losses.
If you add a rotator, there are several additional signals around the compass that would be accessible. The antennas suggested are large, so a combination of rotator plus thrust bearing would be advisable. NTE brand, U-106 & TB-105 is an option. The stronger and more expensive HyGain AR-40 is also worth considering when turning a large antenna.
