Old 17-Aug-2012, 10:37 PM   #5
Tv Reception.
http://www.solidsignal .com , sells a ANT751 with a J mount antenna mount , low dollars.
Aim the ANT751 at about 91 degree magnetic compass direction.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best mount/install the ANT751 at a location that has the least amount to no amount of obstructions in the direction of reception.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
