For best reception of the channels to your East.
Move your Sat pole to the East side of the house, above the roof.
Install an RCA ANT751 antenna aimed to 91 degrees magnetic.
Remove all splitters/diplexers ect. from the satellite system, and replace with ones that are designed for DTV (5-1000 mhz min). You can use the Sat coax.
If you are connecting more than one set, I recommend you install a Channel Master 3410 distribution amplifier just ahead of your first splitter.
