I unplugged all electrical devices (except for the stereo and Tivo connected to the TV) and this didn't make any difference. However, I just replaced the cabling and this may have solved the problem. Actually I just removed the second cable that was being used with a connector and ran a single shorter piece of cable through a window. I haven't seen any pixelation in about 15 minutes whereas I was seeing pixelation several time a minute before I changed the cable. When I changed the cable, the metal connector actually fell off and had to be pushed back on. I think that my current cable (from Fry's) in connection with the old piece of cable from the cable company may be the problem. I just ordered a new 100 ft cable from Monoprice. I'll post an update after the new cable is installed and I've had more time to see if the pixelation returns.
Thanks for all the advice and I'll keep you posted.
