My recommendation is based on the signal strength of the stations you want to receive and the mention that you are not intrested in the 2 edge.
If that is so, based on recommendation of the 751 to many with great results reported in areas with similar signal strength. "Save the bucks".
Another advantage (may or may not be important to you) of the 751 is that is less directional than the larger antenna and should receive more channels from the rear of the antenna.
