A simple solution to receive the stations at 32-34 true North.
Install an RCA ANT751 antenna. This will mount on a satellite 'J' pole such as the Winegard DS3000, for ease of installation on the side of your home. If you mount in a spot with a 360 view, you may receive the strong stations located to the rear of the antenna.
