Old 17-Aug-2012, 4:28 PM   #1
Studly
Need antenna advice: want improved high VHF channels
During the summer only, I have about 1 out of every 5 evenings where I lose reception on channel 9 and 11 VHF.
Here's my current setup:
Antenna placed in attic: Channel Master 4221 - 4 bay (4 bowties)
Preamp: Winegard AP-8700
Also have a Radio Shack FM filter installed.
TV channels: All the main channels I watch are located on the same antenna farm 27 miles away.
I have all the highest quality (quad shield) coax cable and connectors, and have two splitters installed going to three TVs. Since I get great reception most days, I don't think I have any problems with the cable or connectors.
What's odd is before I put in the splitters and added the other TVs, without a preamp, I got a perfect signal when the coax went just to one TV. No channels ever dropped out.
I know splitters degrade the signal, which is why I got a preamp, but it seems odd that before I got the high VHF channels fine using my UHF antenna.
Anyway, during summer only, maybe 1 out of every 5 evenings I'll lose reception or get degraded reception to channel 9 and occasionally ch 11. Normally, I get 6 bars out of 10 for signal strength on those channels. My other channels always come in great.
I'm wondering, what's the easiest and best way to get those high VHF channels to come in better? Should I just move my UHF antenna to the roof top (would require a bit of work to install a mast, rerun some coax, install a mast, ground it, etc.)? Or should I add a high VHF antenna (preferably a compact one) to my existing UHF one in my attic? Or should I replace my UHF with a combined UHF/VHF antenna in the attic?
I'd prefer to keep the attic location for the antenna since we're in Minnesota and I like that it is protected from the weather and my coax is already set up for the attic antenna location. So my first choice would be to get a new antenna for the attic, but if that wouldn't work, then I'd be willing to move everything to the roof top.
My TV fool report: http://www.tvfool.com/?option=com_wr...99000a8e33b9a4
Thanks very much for your advice!
Studly is offline   Reply With Quote
