Old 17-Aug-2012, 3:47 PM   #2
Mounted in the attic, which has the solar shield coating.
You are likely suffering from severe multi-path (rather than a truly weak signal).
Your attic is unlikely to be an easy location due to the radiant barrier. The best thing to do would be to get the antenna out of the Faraday cage it's in. The next best thing would be to try different locations and see if you can find a "sweeter" spot. Opening a strategically located flap (if possible) in the barrier to admit signal would also be suggested as an experiment
