Old 17-Aug-2012, 9:04 AM   #5
Tv Reception.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennasdirect.com , http://www.amazon.com.
___________________
Yes it is Ok to use a indoor antenna such as the Trek HDTVa antenna inside the condo and what ever is received -> is what is received.
Start with the aiming direction at about 220 degree magnetic compass.
Here is how aim indoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
_____________
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
