Old 17-Aug-2012, 4:10 AM   #4
Tv Reception.
The first 2 Digital Tv stations are what will be received with a antenna in the attic , If that is Ok with you then install a Winegard HD7696P antenna with a Channel Master CM7778 preamp in the attic aimed at about 12 degree magnetic compass direction.
___________________________
For reception of more then 2 digital Tv stations install a Winegard HD7696P antenna with a Winegard AP8700 preamp aimed at about 12 degree magnetic compass direction.
Above the roof or at a location that is Up High free and clear of obstructions , as always trees and tree leaves do a real fine job of , reducing or blocking reception and so do buildings and other obstructions.
Here are 2 antenna mounts that do not make holes in the roof , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html, buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box.
http://www.3starinc.com , has push up antenna mounting poles.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com , http://www.channelmasterstore.com.
__________
For 2 Tv's connected use a HFS-2D , 2 way splitter.
Buy the HFS splitter at , http://www.hollandelectronics.com , also at , http://www.solidsignal.com.
___________
