Old 26-Sep-2010, 5:42 PM   #7
No static at all
No static at all's Avatar
Yes, the smallest elements point toward the transmitters. The reason I asked is if an antenna is in fact pointed backwards, it can still work well with strong signals, but will be more likely to pixelate.
The multipath would have to be quite severe to be seen on so many channels, so I'm still leaning towards a cable/connection issue. The 7604 is an excellent antenna for your situation, so I'm sure you will work this out with a little more diagnosis.
