Yeh, I've also been wondering if it's a cabling issue. There are no splitters in the cable but there is a F type connector connecting the original cable used with our cable TV to the new cable running to the antenna. I think I'll try buying a new 100ft cable for one single run from the antenna to the TV.
I have the antenna pointed with the smallest elements pointing towards the tower. I've been assuming that since my signal strength is 93-100 that the antenna is operating correctly and pointed correctly. Is this a reasonable assumption?
If there is multipath interference is there any way to fix this, such as a different antenna or some sort of shielding. Unfortunately I've never had a previous analog antenna to know if this has previously been a problem.
Keep the suggestions coming. I'll report back after replacing the cable.
