I doubt it's interference if you are seeing the issue on so many channels. I would first suspect a cable or connection issue as the 7694 should work more reliably with the stations in the green. Do you know if there are any splitters in the system?
The only other thing I can think of would be multipath interference (signal reflections) which can cause even strong signals to pixelate. Did you ever have an outdoor antenna with analog TV? If so, if there was a lot of ghosting, that would indicate a multipath issue at your location.
Also, are you sure you have the antenna pointed correctly? The end with the reflector should be aimed towards the towers.
