Yup have a patio area, in regard to a clear direction without being blocked, I would have to check I think I should be clear of other buildings in the S/SW direction primarily. I'm on the lower level and the N/NE may require me to mount way atop the complex, or the antenna would need to transmit signal through the rest of the building since the patio is on the lower level around the back.
