Old 26-Sep-2010, 4:24 PM   #2
Try pointing the "business" face of the DB8 west-NORTHwest. 55.1 should be easily received with the DB8 properly aimed.
Channel 10.1 most probably will require the addition of a high-VHF antenna such as our C5 to be received. Sadly, WALA is both the only high-VHF station and the only Fox affiliate within receiving range of your location and will require a either a separate high-VHF antenna added to your existing UHF antenna or would require swapping it out for a competitor's long-range 7-69 combo.
