Old 16-Aug-2012, 6:22 PM   #1
furry
Reception Antenna advice needed with a tough report
Hi,
My report indicated multiple signals in the 30-50 miles range from 3 different points.
http://www.tvfool.com/?option=com_wr...990061341e202f
Its a condo with a patio area and it a bit elevated relative to the rest of the complex. I'm not sure if I will be able to mount a large external antenna but it seems that it would be needed.
What are my chances of capturing 80% of these channels in very good quality? And what antenna would you recommend that would be somewhat discrete and easy to place? If its overly complicated to get good signal at my address I will be forced to get cable
Thanks in advance!
furry is offline   Reply With Quote
