Day to day, do you get reliable reception of WHEC & WHAM? If not, the addition of a High-VHF antenna would improve the situation.
If I were starting form scratch, seeking reliable local reception, I would use two antennas. First, an Antennas Direct DB4e facing east (105° compass). The DB4e has two lobes off the back that are sensitive enough to do a good job receiving the signals from the NW & SW. Second, I would point an Antennacraft Y5713 at 329° compass, aiming for real CH-10 & 13. To combine the antennas into a single down-lead, I'd use a UVSJ close to the UHF antenna, followed by an Antennas Direct CPA-19 preamp.
If your goal is DX hobby reception, use a large combination antenna or combination of large cut-for-band antennas... 91XG, HD9095P, Y10713, YA1713, etc. Also, particularly for DX, mount outside.
Reason: DX
