Old 16-Aug-2012, 2:28 PM   #1
cassb
Do I need a preamp, or a new antenna?
Hi! I was up in the attic adjusting the antenna last night and was pulling in some pretty distant stations, albeit with a weak signal but still enough to capture the digital picture. I had the TV right up there with me next to the antenna and aimed the antenna based on the TV's signal strength meter for the weaker stations.
But this morning, now I can't pull in the same channels (like WPBS and WUTV) that were working OK last night with the TV installed into its original place (with about 100' of 75 ohm cable directly to the antenna). So I'm wondering if a preamp would work in this situation, and which one would meet my needs. Can you help?
Here's my map link.
http://www.tvfool.com/?option=com_wr...9900a924f9fd62
And the antenna I have is one I got from Antennas Direct a few years ago, the 42XG:
http://www.antennasdirect.com/store/...n_antenna.html
Or... instead of a preamp, would a newer antenna like this one be more effective than a preamp on the existing one? http://www.antennasdirect.com/store/...VHF-Combo.html
Thanks!
Bryan
cassb is offline   Reply With Quote
