Old 16-Aug-2012, 2:19 AM   #2
Tv Reception.
A simple reception situation.
Install a ANT751 antenna Above the roof aimed at about 300 degree magnetic compass direction.
Here is how aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
http://www.solidsignal.com has the ANT751 antenna that comes with a J mount antenna mount.
For 1 Tv connection use no splitter and no amplifier.
For 2 Tv's connected use a Channel Master CM3412 distribution amplifier.
For 3 or 4 Tv's connected use a CM3414 distribution amplifier.
__________
Do not use any of the Satellite , splitters , diplexers , etc. .
__________
Mount the ANT751 , Up High.
As always trees and tree leaves do a real fine job of , reflecting , reducing , blocking Tv reception and so do buildings and other obstructions.
Install/mount the ANT751 where there is the least amount to no amount of obstructions of the directions , north west , west , south west.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
_________________
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
