Old 16-Aug-2012, 12:25 AM   #8
Tv Reception.
A simple reception situation.
Above the roof install and aim a ANT751 antenna at about 135 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html
Solidsignal has the ANT751 that comes with a J mount antenna mount.
Not much money.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
The Tv/s Must Channel Scan for the Digital broadcast Tv Channels , sometimes named the 'Air Channels' or "Antenna Channels' in the tv setup menu because the tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
