baud, I have read/thought of a rotor as well. If I go that route, will I be able to do a wall mount? I guess if the wall mount is cantilevered out far enough I could, the range of motion ought not to be that wide a swing. Or, like you suggest I can mount two antennas to pick up the range of signals/antennas. Will look at wall mounts online this afternoon. Thank you, mizzou
