Old 18-Jan-2010, 7:06 PM   #6
Witty1
Almost There!!
I ended up buying an AntennasDirect C2 antenna this weekend from Best Buy to give it a try. I now get 24 stations but I am puzzled as to why I cannot get by local ABC (KOMO) station (once I can get this one, I am good to go).
I have a PC with a tuner card, so I used it to monitor the signal strength as I adjusted the antenna. I was able to pick to pick up a weak signal when I pointed the antenna down towards the ground (20-30 degrees), but this compromised the quality of the other stations.
Also, when I moved the antenna from one location to another, I had it sitting on the ground and it was able to receive KOMO… I thought elevation was my friend, but not quite certain with the results I am seeing!
Any thoughts or suggestions based on my location would be appreciated!
Thanks
Witty1 is offline   Reply With Quote
