Old 15-Aug-2012, 6:19 AM   #2
Tv Reception.
A simple reception situation.
To receive the Denver Digital Tv stations/channels.
Above the Roof install a Winegard HD7696P antenna , with no antenna amplifier , aimed at about 170 degree magnetic compass direction.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
_____________________________________________________
