Old 15-Aug-2012, 5:20 AM   #4
Tv Reception.
A Teleview Recommendation.
Your location has receivable Digital Tv stations/channels in the VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
Examples:
KOMO-TV Real Digital UHF channel 38 , virtual number (4.1) ABC.
KCTS-DT Real Digital VHF channel 9 , virtual number (9.1) PBS.
____________________
Install a Winegard HD7698P antenna that receives the VHF high band and UHF band.
Aimed at about 0 degree magnetic compass direction.
As always , trees and tree leaves do a real fine job of , reflecting , reducing , blocking , Tv reception.
Buildings and other obstructions are also not good for Tv reception.
Mount the antenna where there is the least amount to no amount of close obstructions.
Here are some but not all antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
