The KUNS signal is still broadcast from Tiger Mt. just east of Issaquah, which is were KWPX-ION is broadcast from together with KWDK and a couple other low power signals that you probably don't see. I say all that because you may think your seeing something from Queen Anne when you're not.
KOMO, KING, KIRO, KCTS & KSTW all broadcast from Queen Anne Hill and Capitol Hill in Seattle and call for the highest available gain antenna(s).
A single antenna solution would be a Winegard HD7698P or Antennacraft HBU-55...
Another valid approach would be a separate UHF antenna and a High-VHF.
UHF: Antennas Direct 91XG or Winegard HD9095P
H-VHF: Antennacraft Y10713 or Winegard YA1713
I would not write off more antenna altitude if you can afford it. You don't need to achieve LOS in order for additional height to be of help.
What make/model preamp are you using now?
