I concur with teleview's recommendation.
If you want to shop valid alternatives, then consider an Antennas Direct 91XG. (A direct competitor in terms of size and performance, but it can be tilted slightly. In your case, this may be helpful. You would aim at the top of the ridge that blocks your view of the transmitters.)
An alternative to the CM7777 would be an Antennas Direct PA-18. (A dB or so lower noise... that's not a big difference.)
As teleview has already stated, you'll get better results if you mount outside, clear of obstructions. Mounting in the attic is going to cost you valuable signal strength and put the antenna closer to interference generating motors, lighting fixtures, computers, etc.
