Tv Reception.
Because the signals are weak.
Because of the 5 Tv's connected.
Every time a splitter split takes the signal is reduced.
I am staying with my recommendation , HD9095P antenna , CM7777 preamp , and etc. .
_____________
You can install the system that you choose.
If reception is Ok , well then Ok.
If not then return the reception equipment for a refund and try again.
_____
You can invite the other advisors to provide evaluations.
