Old 15-Aug-2012, 1:16 AM   #3
From your description, it's a bit unclear... are you connecting your antenna to an active cable TV service? If so, please don't. Cable TV services use the same frequencies as over the air life safety services (police, fire, aircraft nav & comm, etc.). If you connect an antenna to the cable network, you risk interfering with licensed radio services.
We need to know how your internet service is delivered, cable, phone company DSL, wireless, satellite...?
Are you using a Ethernet to RG-6 adapter of some sort? If so, what make and model.
What did you connect the antenna to? A splitter input port, output port...?
Bottom line, we need a detailed description of the existing cabling system... before you connected any OTA antenna components.
