Tv Reception.
Step 4 .
The cable tv delivered internet or any other type or kind of pay cable delivered service Will Not be connected to the antenna or the antenna system in any shape or from.
Step 5 .
The Pay cable system and antenna and antenna systems are 2 SEPARATE Systems and Will Not be connected togather in any way shape or form.
Step 6 .
Do Not connect the cable system and the antenna system on to the same coax.
___
The Pay Cable system and Tv Antenna Reception use many of the same frequencies , mixing Tv antenna signal and pay cable on to one coax , Will produce the problems you are having.
The 2 systems must be 2 Separate coax systems.
Most likely only one coax is connected to the wireless internet router.
If Tv antenna signal is required in the room where the wireless router is at , then run a separate coax.
The rest of the coax through out the house can be used for the Tv antenna system.
