Old 25-Sep-2010, 8:20 PM   #1
JimRPh
Antenna Advice? Gulf Breeze, FL
I have a DB8 antenna from AntennasDirect.com that I installed in January 2006. It is mounted roughly fifteen feet high, about level with the roof peak. It is pointed approximately West-Southwest.
My report from this site is at:
http://www.tvfool.com/?option=com_wr...a36211e2f7c2d2
I get a good number of channels, but the CW (55.1) channel has a weak signal and the FOX (10.1) channel is not received at all. The reason I need to improve the 55.1 CW channel is that my TIVO doesn't include 44.1 CW in my lineup. There are other channels that find just enough signal for my TV to tell me their ID, but not enough signal to get a picture.
Would an antenna amplifier help? Do I need a better antenna? Or am I simply outside the limit for these channels. I do use an indoor distribution amplifier.
The channels I do get are:
ABC WEAR 3.1
CBS WKRG 5.1, 5.2, 5.3
NBC WPMI 15.2, 15.2
IND WMPV 21.1, 21.2, 21.3, 21.4, 21.5
PBS WSRE 23.1, 23.2, 23.3, 23.4
IND WHBR 33.1
IND WFGX 35.1, 35.2
CW WJTC 44.1
CW WFNA 55.1
JimRPh is offline   Reply With Quote
