Tv Reception.
Yes of VHF high band channels 7 thru 13.
Channel 7 is the most effected by multi path signal reflections and other interfering signal transmissions and then channel 9.
Channels , 8 , 10 , 11 , 12 , 13 , not so much.
____________________________
Omnidirectional antennas are not 100% omnidirectional, sometimes it can help to turn the antenna to find a position that has a little better reception.
It is still Ok to install the HD7696P antenna.
_________________________________________
If you will like to find out more about the Tv stations and what is on.
As an example:
Type variations of stations call signs in the google search box.
wjfw , wjfw tv , wjfw-tv , wjfw 16 and etc.
w27au , w27au tv , w27au-d , w27au-d 27 and etc.
The 2 main web sites that will pop up with practical and useful information are , wikipedia and rabbitears.info
