Bent antenna
I'm not sure if I should continue where I left off. I ordered the winegard HD7000R antenna as recommended, I finally got around to opening the box after 3 weeks, was ready to install it. Unfortunately, the rods on the antenna were bent into a perfect curve, almost looked like it was made that way. Here is my problem, they are out of stock and don't know when they will be getting them in. I ordered this with the Sonora HFS-3D DBS satellite diode steered 3-way splitter and the Ronard 3442 Eave mount, all from Solid Signal. Should I get my refund and find the same antenna some place else or order a different antenna. Thanks for your time,
Steve
