Old 13-Aug-2012, 2:31 PM   #1
BJE80
Issue receiving a station I should be receiving
Hi all. I am looking for some help receiving one station I should be easily getting.
I have put up a Winegard 2002 Omnidirectional antenna on our cabin 23' in the air on an eave mount. The reason I put a Omnidirectional antenna up is because the local NBC station is in the opposite direction than the other stations and I did not want to deal with a rotor for a cabin.
http://www.amazon.com/Winegard-MS-20...=winegard+2002
I ran 75' of RG-6 coax to our Sayno 39" Flatscreen.
http://www.walmart.com/ip/Sanyo-39-C...39842/21118776
Here is my signal analysis.
http://www.tvfool.com/?option=com_wr...99001b798393d9
So here is my problem. For some reason I don't receive WSAW-TV Channel 7 CBS. What is weird about it is that I receive Channel 9 WAOW (ABC) and Channel 20 WHRM (PBS) just fine and their towers are in the exact same location. It does not appear like the Channel 7 has a lower power or anything. So why can I get ABC and PBS and can't get anything for CBS? It doesn't make any sense to me.
Also, those towers are only 18.2 miles from me. I marginally receive channel 12 WJFW NBC 40.2 miles away which is about the extended range for this antenna. That tells me all my connections are good.
Please give me your thoughts. Thanks.
BJE80 is offline   Reply With Quote
