Old 25-Sep-2010, 5:53 PM   #24
Billiam
Another thought. After rereading your TV Fool report I had another idea.
It seems as though the weakest signals you wish to watch are on VHF. I've found the Winegard HD 7084 antenna has about the highest gain for VHF in all band antenna. Perhaps only the Channel Bastard 3671 has more gain but that is a monster in size. The 7084HD would cover your Ch. 5 in the lo VHF band and high band stuff as well. You could then use something like a Winegard AP 4800 VHF only pre amp and bypass a pre amp on UHF which this antenna should not need for the signals in green and yellow on the UHF band.
